hannes603 Posted October 11, 2024 Share Posted October 11, 2024 (edited) wondering how that could work. in my setup all wedges getting flipbbooked in one videofile. For each color/wedge index change, i want to export an individual flipbook. Below you will find the scene. Thanks untitled.ffmpegencodevideo1.03..mp4 topnet.hip Edited October 12, 2024 by hannes603 Quote Link to comment Share on other sites More sharing options...
paranoidx Posted October 12, 2024 Share Posted October 12, 2024 In this case, "Wait For All" is not necessary. This node will combine all the results (or "total frame ranges of all wedges") into a single stream. You might want to use "Partition By Frame" node to create partitions for the "Frame Ranges." Then, use "Split by Attribute" with "wedgeindex." After that, you can continue with your video export workflow, and it should work smoothly. 1 Quote Link to comment Share on other sites More sharing options...
hannes603 Posted October 12, 2024 Author Share Posted October 12, 2024 5 hours ago, paranoidx said: In this case, "Wait For All" is not necessary. This node will combine all the results (or "total frame ranges of all wedges") into a single stream. You might want to use "Partition By Frame" node to create partitions for the "Frame Ranges." Then, use "Split by Attribute" with "wedgeindex." After that, you can continue with your video export workflow, and it should work smoothly. thanks! i typed the wedge index directly in the wait for all node... working now 1 Quote Link to comment Share on other sites More sharing options...
