lacer8 Posted October 30, 2024 Share Posted October 30, 2024 Hi there and thanks for your time. This must be the most basic of things, but I just can't figure out how to make it work. Basically I want to take any mesh, and relocate it so the mesh sits with the top centered at 0,0,0. I need to do it procedurally because the object who's pivot I need to change isn't always the same. I've attempted using a transform node and Pivot Translate options like $CEX, $BBX, $CEZ, but I think the $BBX syntax is incorrect and even if that worked, I'd still be stumped on how to reposition the mesh to 0,0,0 regardless of where it started from. Thanks again. Quote Link to comment Share on other sites More sharing options...
ryew Posted October 30, 2024 Share Posted October 30, 2024 Have you already tried Match Size SOP with "Justify Y" set to Max? It sounds like what you are trying to do manually. Quote Link to comment Share on other sites More sharing options...
fencer Posted October 30, 2024 Share Posted October 30, 2024 Check cookbook "Equivalencies and differences" https://www.sidefx.com/docs/houdini/ref/expression_cookbook.html Try to use "-$YMAX" toP0_v01.hip 1 Quote Link to comment Share on other sites More sharing options...
lacer8 Posted October 30, 2024 Author Share Posted October 30, 2024 Thanks Ryew and fencer! Ryew, yes, the match size is exactly what I needed! What a silly boy I am! Thanks for the suggestion. I'll check the cookbook you linked, fencer. I'm sure there's lots of interesting stuff in there. It's been a while since I looked at it. In fact, it's been a while since I used Houdini at all! Thanks again! 1 Quote Link to comment Share on other sites More sharing options...
