Getting The Velocity Of Imported Animated Object
ykcosmo
I imported the animated object from maya as xxx$F4.obj. I want run the RBD with the object in houdini. How to get the velocity of the imported animated object (I have turned on the "use animated object"). It seems that if there is no velocity, the collision won't happen....even I animate the object in sop level with keyframe........
