Masoud Posted February 1 Share Posted February 1 Hi everyone, Could you please take a look at the image below? I'm working on scaling a curve (which isn't at the origin) using VEX code. I need the scaling to be based on point number 0 (@ptnum = 0). Does anyone have any ideas or suggestions on how to approach this? Thanks in advance! Scale.hip Quote Link to comment Share on other sites More sharing options...
osmanertasdiken Posted February 1 Share Posted February 1 You can achieve this using either VEX or a transform sop with an expression on the pivot translate, I included both methods in the hip file. Best, Scale_odForce.hiplc Quote Link to comment Share on other sites More sharing options...
Masoud Posted February 6 Author Share Posted February 6 Hi Osmaner Thank you for your response. In your file, when I change the point number, the curve shifts to an undesired location. Quote Link to comment Share on other sites More sharing options...
Masoud Posted February 6 Author Share Posted February 6 These codes helped me to achieve it: vector T = chv("T"); vector R = chv("R"); vector S = chv("S"); vector pivot = point(0, "P", chi("Point_Number")); matrix m = maketransform(0,0,T,R,S); matrix m2 = ident(); translate(m2,-pivot); m2 *= m; translate(m2,+pivot); v@P *= m2; Quote Link to comment Share on other sites More sharing options...
