Rafal123 Posted August 30, 2007 Share Posted August 30, 2007 imagine you have locked camera and wanna do some manual transformation of geo which is outside of screen, in app M you can select one of the transform(xyz) of the geo and then using middleMouseButton I can transform it with no need to see it, is that something like that in H ? Quote Link to comment Share on other sites More sharing options...
michael Posted August 30, 2007 Share Posted August 30, 2007 I've RFE'ed this 4 or 5 times.... the only way to do this now is to have two views...one from, in your case, the camera, the other from a different view that shows your transform jack - in which you can manipulate it... HTH Quote Link to comment Share on other sites More sharing options...
Rafal123 Posted August 30, 2007 Author Share Posted August 30, 2007 thanks man Quote Link to comment Share on other sites More sharing options...
edward Posted August 31, 2007 Share Posted August 31, 2007 Er, but I don't understand why you can just change the value in the parameter dialog? If you select the parameter in the Channel List pane, you can hold down the j key and do the app M thing in the viewer. Quote Link to comment Share on other sites More sharing options...
michael Posted August 31, 2007 Share Posted August 31, 2007 it's not about not being able to change values...it's about being able to visually change the values Quote Link to comment Share on other sites More sharing options...
edward Posted August 31, 2007 Share Posted August 31, 2007 ...I can transform it with no need to see it... ? Quote Link to comment Share on other sites More sharing options...
