Rival Consoles Posted February 22, 2025 Share Posted February 22, 2025 (edited) Hi there folks, I have a question that seems to be simple but I'm struggling to make it work. For the sake of illustrating the problem, I have 2 grids with different patterns but same poly count. I'm trying to add the points position from pattern 2 to pattern 1 so I have only one grid with both patterns merged. The trick is, I need to see both patterns on the same grid. That being said, I'm not intending to use VDB combine and I have tried in a point vop multiplying the position of both grids then adding the result to the original pattern 1 position but to no avail. Also tried using the minpos function in a point wrangle but no success. I have done this in vops using noise but for some reason, manipulating the points in a similar fashion is not working. Any ideas on how to approach this challenge? Attached are the pattern imgs and hipnc file. combining_two_patterns.hipnc Edited February 22, 2025 by Rival Consoles Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted February 23, 2025 Share Posted February 23, 2025 Hi, use Ray sop, Direction from - Vector, Ray Direction - 0, 1, 0 1 Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted February 23, 2025 Share Posted February 23, 2025 .. or use the maximum height from two ray nodes. combining_two_patterns_KM.hipnc 1 Quote Link to comment Share on other sites More sharing options...
