Simple RBD Explosion
Fakit
Hello everyone,
A simple issue that I don't understand : RBD Explosion.
You'll see in the setup attached :
- A base geo (head)
- A quick fracture work (mask + fractures)
- RBD Configure (with active bound)
- A bullet solver
Then, I feed an AttributeAdjustVectorFloat for the Velocity (3rd input/proxy).
--> Frame 1 = Velocity Data OK
--> From Frame 2 = v@v = {0,0,0}
If I deactivate "constraint" in the RBD Material Fracture, then, I have Velocity data.
Normal --> No constraints.
But even If i put 0.0001 for the Glue constraint : Same !
As usual, this is possibly a very simple and dumb thing.
Let me know if you can enlighten me.
Thank you !
Ps : Here's a simple tutorial about that.
Simple_RBD_Explosion.hipnc
Edited by Fakit
Thank you for your answer @Sepu !
Yeah that's what I saw. It works If I disable the constraints.
But let's say that I need them. I should be able to break the constraints with velocity with a very low Glue value no?
Thanks
you can not break as I said above glue constraint with just velocity.  You need to create some kind of impact like things colliding with them, events, falloffs, etc.
Have a look at this and it will give you quick overview of constraints
