Foreach Sop
AndrewVK
Lets suppose i have an polygon and i want to split it randomly into pieces.
grid -> clip (keep both mode) -> clip (new parameters) -> clip (new parameters) e.t.c
It can be done with help of hscript...but help for "ForEach SOP" says:
For Each Number:
Repeat the set of SOPs a set number of times,
feeding the result of each iteration back to the start.
Unfortunately i can not reproduce this functionality.
If i turn off "merge result" - i have an polygon splitted in last iteration.
If i turn on "merge result" - i have 10 splitted polygons
But I have expected polygon splitted 10 times.
Can it be done?
For Each Number:
Can it be done?
Forgive me if I'm completely wrong about this, but are you putting the sops you want to repeat inside the foreach node? It's not documented like that, and I actually have no idea if that's how it's supposed to be used, but that's the only way I've been able to get results I want with it.
So for instance, if I wanted to subdivide geometry twice, jump inside the foreach, apppend the subdivide to the each node, put input geometry into input 1 of the ForEach, and turn "merge results" off.
Of course, subdividing with depth 2 is easier, but I'm trying to make a point!
Edited by Darric
Here what i want and what i have
foreachtest.hipnc
Hey Andrew,
Good you bring this topic again, I was struggling with similar problem some time ago, but just today found the way to fix that. The answer is pretty simple, just change the order of your each and clip SOPs and you will get the right result.
cheers
kuba
foreachtest2.hipnc
Edited by kubabuk
Hey Andrew,
cheers
kuba
Thank You kuba!
I think this strange fact should be noted in the documentation...
