zura Posted April 25, 2025 Share Posted April 25, 2025 I have made a simple emitter of vellum cloth spheres. I now want to randomize the pscale of each sphere. I thought the best method would be to actually just randomize the pressure/ rest length of each sphere but im having no luck 2025-04-25 22-14-38.mp4 It looks like its working on the very first sphere somehow Thanks so much for any help testing random pressure restlength.hip Quote Link to comment Share on other sites More sharing options...
zura Posted April 25, 2025 Author Share Posted April 25, 2025 solved myself, file below if it helps anyone out =) the solution was to add ids to the points and simply feed the geo direct into the solver using "each frame" instead of using "instance on points" mode within the vellum source dop testing random pressure restlength.hip 1 Quote Link to comment Share on other sites More sharing options...
hannes603 Posted April 28, 2025 Share Posted April 28, 2025 vellum_emit_restlength_by_patch_name.hip you can also use patchname as restlength scale Quote Link to comment Share on other sites More sharing options...
