Coz_y_not Posted Sunday at 03:52 PM Share Posted Sunday at 03:52 PM Is there a correlation between the size of simulation cache and the GPU needed for viewing the result or making a flipbook? If the workstation is only meant for simulation (very large caches) and CPU rendering, can I get away with literally a trashy GPU? Quote Link to comment Share on other sites More sharing options...
Atom Posted Sunday at 08:48 PM Share Posted Sunday at 08:48 PM If you're running below spec, (i.e. less than 12GB vRAM) you might consider using the OpenGL rop in the /out context for producing your flip books. There are controls on the rop to customize the quality. Another thing you can try with heavy geometry is to poly-reduce it or quad remesh it to a produce a lower primitive count. This reduction can help the view port. Also move your mouse over the 3D viewport and press the D-KEY. There are quality controls for the viewport under several tabs. Quote Link to comment Share on other sites More sharing options...
Coz_y_not Posted 17 hours ago Author Share Posted 17 hours ago To be specific how much vRam should I have to visualise and make a flipbook of a high resolution large (very large) scale flip sim? Do I need to stack up vRam by adding multiple GPUs that have 32GB vRam each? Quote Link to comment Share on other sites More sharing options...
