2 x CPU = 1/2 simulation time ?
Coz_y_not
Will I cut the simulation time by half if I use a dual cpu set up?
I'm asking because dual cpu set ups seem to sacrifice a lot of stuff just to be able to squeeze the 2 cpus in the usual motherboard forms.
I can  test it for you if you want. You have to provide a minimal HIP file that I can open in Apprentice ,and I can give you the time it took to compute your sim.
My H workstations are:
Vendor ID:                GenuineIntel
  Model name:             Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
    CPU family:           6
    Model:                79
    Thread(s) per core:   2
    Core(s) per socket:   14
    Socket(s):            2
    Stepping:             1
    CPU max MHz:          3500,0000
    CPU min MHz:          1200,0000
and another similar but a bit older 2 x E5-2670 v1
That's 56 CPU threads total.
