Translate To Origin
petz
append transform sop and put in pivot xyz:
$CEX $CEY $CEZ
that brings transform handle to the centroid of the object.
In the translate fields type:
-ch("px") -ch("py") -ch("pz")
which puts your object back in the origin.
save as preset for later use.
cheers
kuba
Edited by kubabuk
also if the object is animated you can try branching a cache of frame 1
then using point to do the translation ($TX - $CEX2, $TY - $CEY2, $TZ - $CEZ2),
where CE2 is from the cache.
If you are using H9, you can also use the TimeShift SOP and set the frame value to 1 in order to get the centroid.
