iaiotom Posted November 25, 2007 Share Posted November 25, 2007 Hi, this is my first post, so i aks a simple question. I have a very simple scene, a box sop wired into left input of a copy node and a grid with a little noise wired into the right input of the same copy node. then in the copy parameter i turned on the create output grups with box$PT how parameter. Now i connect a delete node to delete all cubes that they are a TY position under 0.1, so in the filter expression of the delete node i wrote prim("../copy1",$PT,"P",1)>0.1, but this is not correct because it doesn't consider groups and it deletes faces with y position under 0.1 and not all the cube. So how can i resolve this problem??? thx PS sorry for my bad english Quote Link to comment Share on other sites More sharing options...
Jason Posted November 25, 2007 Share Posted November 25, 2007 iaiotom said: Hi,this is my first post, so i aks a simple question. I have a very simple scene, a box sop wired into left input of a copy node and a grid with a little noise wired into the right input of the same copy node. then in the copy parameter i turned on the create output grups with box$PT how parameter. Now i connect a delete node to delete all cubes that they are a TY position under 0.1, so in the filter expression of the delete node i wrote prim("../copy1",$PT,"P",1)>0.1, but this is not correct because it doesn't consider groups and it deletes faces with y position under 0.1 and not all the cube. So how can i resolve this problem??? thx PS sorry for my bad english Hello and welcome! Make sure you are set to delete points in the Entity field in the Delete SOP. Firstly, you are using the prim() expression when you could be using a point() expression. Secondly, you should be able to just use a simplified expression "$TY < 0.1" - this should work in the same way. Hope this helps, Jason Quote Link to comment Share on other sites More sharing options...
iaiotom Posted November 25, 2007 Author Share Posted November 25, 2007 Jason said: Hello and welcome!Make sure you are set to delete points in the Entity field in the Delete SOP. Firstly, you are using the prim() expression when you could be using a point() expression. Secondly, you should be able to just use a simplified expression "$TY < 0.1" - this should work in the same way. Hope this helps, Jason hi jason, i have tried with $TY<0.1 but it's not good for this case. I need in the delete node an expression that return the center of the bouding box or the pivot's position of each groups, so if the center of the group is <0.1 i can delete this group. there is an expression like that? thx for your help iaiotom Quote Link to comment Share on other sites More sharing options...
Jason Posted November 25, 2007 Share Posted November 25, 2007 iaiotom said: hi jason,i have tried with $TY<0.1 but it's not good for this case. I need in the delete node an expression that return the center of the bouding box or the pivot's position of each groups, so if the center of the group is <0.1 i can delete this group. there is an expression like that? Hi there, No, unfortunately not. I have often wanted something like that myself, actually. I think you might find yourself looking up how to do Stamping with the Copy SOP. Copy-Stamp is a very powerful feature that might solve all your problems. Or you might find yourself using the ForEach SOP and looping over the groups in your geometry. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted November 26, 2007 Share Posted November 26, 2007 I'm probably missing something but can't you just use your expression to delete the points you are copying too and therefore avoid having to delete the boxes afterwards. Quote Link to comment Share on other sites More sharing options...
iaiotom Posted November 26, 2007 Author Share Posted November 26, 2007 eheh the solution was simple. first i delete the points with $ty<0.1 and then i copy the box so it works. thx iaiotom Quote Link to comment Share on other sites More sharing options...
