brain Posted February 11, 2003 Share Posted February 11, 2003 Hi, I downloaded the Vex's for water, but I have no clue how to get these to work. I am using Version 4.0. Tried to copy the *.vfl files somewhere in the Houdini directory, but it does not work. Thanks for any advice. Quote Link to comment Share on other sites More sharing options...
stevenong Posted February 11, 2003 Share Posted February 11, 2003 Hi there, In the Scripting.fmk.pdf file, there is a good introduction to VEX. Included in the documentation are the steps necessary to setup directories & index files for VEX files. When creating the directories & index files, please take note of the capitalization (or non-capitalization) as Houdini is case sensitive. Also, there is a good shader writing tutorial in the Tutorials section of odforce which should help you too! Have fun! Cheers! steven Quote Link to comment Share on other sites More sharing options...
Carlos Posted February 11, 2003 Share Posted February 11, 2003 Hi Brain, I've put together a mini step by step written tutorial on this: http://www.visualparadigms.com/houdini/for...wtopic.php?t=10 It's actually been up there for a while now --Carlos Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted February 12, 2003 Share Posted February 12, 2003 If anyone is interested and John Coldrick doesn't mind I can post a modified version of John's mshop. You can set the renderer to be mantra instead of prman so you can compile a .vfl instead of a .sl. It will automatically move the .vex and .ds files to the correct project ($JOB) folder and also create/edit the corresponding VEXxxx/SHOPxxx file. Scripting == time savings == more time on odforce jim. Quote Link to comment Share on other sites More sharing options...
brain Posted February 13, 2003 Author Share Posted February 13, 2003 Thanks everybody. Quote Link to comment Share on other sites More sharing options...
