Op:../ Not Working?
Marc
  Quote
Anyone know why this :
op:../../copnet/logo_out
works in v8 and not in v9? This is for a shader diff map field.
Yeah, its a bug that has been fixed. what build are you using? It works in 9.0.783. Also, I dont think op: likes relative paths. It only works on absolute paths.
Edited by SpencerL
crap, we only have 9.0.725 here at work.
The relative path worked in 8, so theoretically it should work in 9 too. This is going to be bundled in an hda, so an absolute path may not be the best bet.
  Quote
yeah, and unfortunately Im not really sure what work arounds there are aside from sourcing the actual file
  Quote
in a perfect world where op: did work then you can use opfullpath() to get the absolute path from your relative one, but now that Im thinking about it it may have been with just point clouds where op: needed a full path.
