CeeGee Posted December 20, 2007 Share Posted December 20, 2007 Hi this is my Rnd for waterfall with Realflow http://rapidshare.com/files/77967064/waterfall_high.mov - 13mb I want to do same thing with Houdini.. I setup the scene but a have a problem whan a run the simulation particles are not collision with waterfall geometry. Then a put hihger value in tab collsion - Volume - mode Ray intersect - division from 10 - 200 after that particle colide with surface but some of the is going true the surface... Here is the scene. Work is done in H9.1 http://rapidshare.com/files/77968358/waterfall_05_H9-1.rar - 4mb Thank you... Quote Link to comment Share on other sites More sharing options...
kleer001 Posted December 21, 2007 Share Posted December 21, 2007 can't see the file. Quote Link to comment Share on other sites More sharing options...
dbukovec Posted December 21, 2007 Share Posted December 21, 2007 hi! The problem is that Your geometry can't be converted to volume collision representation, i dropped cloth in maya to your geometry and made a solid model from it, volume collision now can be adjusted very well and the particles collide with it. Hope it helps. waterfallNewCollsionGeo.zip Quote Link to comment Share on other sites More sharing options...
CeeGee Posted December 21, 2007 Author Share Posted December 21, 2007 Thanks a will try Quote Link to comment Share on other sites More sharing options...
CeeGee Posted December 21, 2007 Author Share Posted December 21, 2007 i try with my geometry, there si one plane that fill holes beatween rocks, i just extrude him and work fine now... Quote Link to comment Share on other sites More sharing options...
