Waterfall With Particles
CeeGee
Hi this is my Rnd for waterfall with Realflow
http://rapidshare.com/files/77967064/waterfall_high.mov - 13mb
I want to do same thing with Houdini..
I setup the scene but a have a problem whan a run the simulation particles are not collision with
waterfall geometry. Then a put hihger value in tab collsion - Volume - mode Ray intersect - division from 10 - 200
after that particle colide with surface but some of the is going true the surface...
Here is the scene. Work is done in H9.1
http://rapidshare.com/files/77968358/waterfall_05_H9-1.rar - 4mb
Thank you...
hi!
The problem is that Your geometry can't be converted to volume collision representation, i dropped cloth in maya to your geometry and made a solid model from it, volume collision now can be adjusted very well and the particles collide with it. Hope it helps.
waterfallNewCollsionGeo.zipFetching info...
