Pinched Track
cspears2002
I'm still working on my rollercoaster. I finished my car, and now, I am moving on to the track. I tried to create a simple track by sweeping a squished circle along a curve. While I like the look of the beginning and end of the track, I can't figure out why the center has a pinched look. Any suggestions? I included zipped directory that has all of my scene files, etc.
rollercoaster.zip
  • 1 month later...
hey... so I just saw this, was about to respond and then noticed it was posted in december. Hopefully you managed to solve your problem by now, but if anyone else is struggling with this problem then here's something to try.
If you duplicate the backbone curve, translate it out a bit, then edit the curves to have a similar path and put that into a rails SOP then it will work better. Especially if you turn on 'use direction'.
Cheers
Marc
