Palpus
ddingddong
  • 2 weeks later...
You can use metaball groups (Meta Group SOP) to prevent the different metaballs from fusing.
See the attached file on how to set this up. I put comments on the appropriate SOP nodes.
metagroups.hipFetching info...
Note: What looks like fusing in the viewport is not really fusing. Just an LOD issue. You can crank up the LOD in the viewport using the "d" display options > Viewport and increase the Level Of Detail slider. This will severely impact your viewport performance.
Note: Meta Groups are supported by the Deform Metaball and Deform Muscle SOPs.
  • 3 weeks later...
Wow~ :ph34r:
Now I check your reply and It's lovely tip to using metaball.
I'm always consider about metaball *jiggling*. I have clue now.
Thanks again~
