Point Oven Mdd Import/export Sop
Guest xionmark
Guest xionmark
Hello,
Attached you'll find plugins for Houdini to import and export Point Oven MDD files. The code is alpha-alpha, needs more testing, a few more features, etc. so use with care and please report bugs. I wanted to get it into the hands of a few people I know may need to use it soon. Free time is scant so I'll work on it more over the week ahead and will also have the Maya PDC importer/exporter done soon as well.
Thanks,
Mark
Hey Mark!
Thanks for your efforts. Just one question. How it would be to compile PO&MDD routines into C++ library with python bindings? And then preparing Houdini interface with HOM and HDA? This would avoid us (you;)) to recompile constantly the asset with the same or similar performance, is that right? I could be wrong, I can't do it myself, but using other Python C modules (like PyOde) liberate me from worried about H.9.1.??? issues...
thanks again for you great tool!
Simon.
Guest xionmark
Hey Mark!
Simon.
Hi Simon,
Good idea. I did some of that sort of thing a few years ago when I first started using Python (wrote a MIDI driver in C that was called by Python).
Let me dig around and look into it.
Thanks for the idea!
Mark
hi!
This is really great, as is Eetu's stuff too.
I just have a lame question, how to load these? I created a dso folder in my h9 prefs folder, but can't see them as SOPs.
thanks!
Place the DLL or DSO files in $HOME/houdini9.1/dso/ directory.
Mark
Guest xionmark
I placed it there, but I don't see them, probably because it is compiled with the production build and I'm using the latest daily?
In the textport, type in dsoinfo -s, the plugin should show up in the list.
Should look something like this:
/ -> dsoinfo -s
-- SOPs
GroupDelete C:/DOCUME~1/mstory/MYDOCU~1/houdini9.1/dso/SOP_GroupDelete.dll
IMG_Import C:/DOCUME~1/mstory/MYDOCU~1/houdini9.1/dso/SOP_IMG_Import.dll
MDD_import C:/DOCUME~1/mstory/MYDOCU~1/houdini9.1/dso/SOP_MDD_Import.dll
MOLA_Import C:/DOCUME~1/mstory/MYDOCU~1/houdini9.1/dso/SOP_MOLA_Import.dll
<SNIP>
If it 's not in that list, the plugin is not in the correct location.
What OS are you running?
Mark
Guest xionmark
ok, it's there, but houdini drops a fatal error if i try to put down the node, using win32. I'm probably using some other version than Your's. Can I knwo against wich version is the plugin compiled?
Thanks!
It's compiled for H9.1.124
Guest xionmark
I'm also getting a fatal error (Segmentation Fault) on Win32 (9.1.124).
I created a box, added the export node, and it crashed whenever I clicked "Write MDD File."
Did you try the example hip file?
I've had no problems.
I'm pretty sure there's a point count limit in the MDD file of 65535. Is your grid larger than that?
Mark
Guest xionmark
The MDD_dev_v1.hip file crashes on me upon opening it (Segmentation Fault.)
The box I tried was 8 points.
I'm using the Apprentice version. Could that somehow be the cause?
That's very odd. Apprentice should load plugins fine.
I've tested on WIN32, works fine.
But again, I don't have a copy of Maya or Max so that I can write out MDD files, I'm depending on others to generate MDD files for me to test.
I don't have a windows machine at work but will check again tonight at home.
Mark
Guest xionmark
Just tried it now on a WIN-XP machine, no crashola ... works fine.
Mark
Guest xionmark
I can't reproduce the error (not saying there isn't a bug), there's gotta be a reason ...
