Noob Question
MotzVFX
I'm making a tunnel with panels that I want to slightly rotate to focus on a floating object as it passes by. I've already constructed the tunnel in a way that I think will work, but I'm stuck on how to get each panel to focus on a specific object. I tried using a primitive sop to get the panels to look at a Null object, but I think it's telling each primitive in the panel to look. I've included my .hip file (v 8.2) with a simple example of the principle and the tube I built that I want the same principle to work on. Thanks for the help
tube_01.3.hipFetching info...
How about something like this with a ray sop. I haven't done anything fancy to it.
  cpb said:
attached is a semi-procedural attempt, the tube curve can be changed,
but the tube panels have to be identical; connecting up a fragmented
teapot won't work :( It would be doable if I could figure out how to
explicitly set primitive normals...
ray_tube.hipFetching info...
