Particle Split Collide Force Confusion
rdg
still I am very confused about particle setups
I emit one particle that collides with a plane.
On collision it splits into multiple particles.
Those in turn split into a third generation after some time.
All particles should be affected by a force.
All particles should collide with the plane, but only the source generation should split.
The only way I get this done is to have colliders and forces after each split.
Now I understand I have to collect the particles as splits seem to be something like a source.
I attached a file for demonstration.
If you press play every thing seems to behave like expected.
After one loop the system stops because of missing groups - something it didn't bother about during the first run.
spark.hipnc
What am I missing?
Georg
I guess I don't get the order of execution.
I understand this as some kind of "uninitialised variables".
Now I added dummy groups before the splitting. They have the right names but no content and are set to "preserve group".
Georg
Here you go.
Thanks!
I had this before - interestingly in your lineup the split particles react to the force as well.
But they don't collide with the mesh ... if I raise their lifespan ...
It probably offers more control to have a collisionPOP for every generation?
I had the impression that operator after a split only affect particles of this very split.
Thats why I started to branch off and recollect.
I attached my fixed file:
rdg_spark.hipnc
Georg
