Instances
Bernard
Hello,
I've got a particle system generating colored particles (ramp: $LIFE).
Then I instanced boxes to the particles.
Now I want to pass the color of the particles to my instanced geometry (boxes)
How can I do this? (an example hip file would be very welcome :D )
using H 9.1.173, windows xp
thanks,
bernard
Edited by Bernard
Hey,
Here's a link for the "Houdini Master Class Course Materials"
http://www.sidefx.com/index.php?option=com...&Itemid=132
Download the "Shading and Rendering in H9" course material. In there there's some example files together with a powerpoint/openoffice presentations discussing the subject.
Hope this helps,
Cheers
Hey,
Hope this helps,
Cheers
Thanks,
I will look into this valuable material....
bern
Hey,
Hope this helps,
Cheers
Hello,
thanks for the link, but in the Powerpoint presentation I don't find anything of passing color to shader....
bern
there's a file there called "procedural.hip" that does what you want.
cheers
OK, thanks ihab.
I looked at the hip and they used copy sops. Is it also possible without the use of 'copy sops' ?
I've got a Location POP emitting particles going through a Color POP( ramp with $LIFE)
I've use the Instance Geo . Connecting the Material SOP to my POPNetwork and overiding the color doesn't seen to work...
I want the cubes inherit the color of the particle points.
I included my hip file. Maybe you can find what's wrong.
Thanks,
bern
instance_h9.hipnc
Edited by Bernard
hello,
does anybody have a solution for this simple scene: particle system, instanced geometry, transfer particle color(not 'point' color) to shader....
In Houdini 8.2 it was so easy as '1-2-3'....
thanks
Edited by Bernard
hey,
the problem with your file is that the material sop was looking for primitive attributes (1st drop down menu) I changed it to point attributes and everything works as expected. When i used $CR, $CG and $CB in the colors of the material i had an error so i replaced it with a point expression. I attached your modified file.
Cheers
instance_h9.hipnc
hey,
Cheers
instance_h9.hipnc
Thanks ihab,
you are fantastic!
now it works....and I can stop pulling my hair out.
greetings,
bern
