sibarrick Posted April 4, 2008 Share Posted April 4, 2008 The MSI is supposed to only append to the HOUDINI_PATH and HOUDINI_DSO_PATH variables. Uninstalling is supposed to revert them to their previous state. I haven't tested with those two env vars set to anything before installing. I wouldn't be at all surprised if the MSI uninstall just wipes them. There's not much I can do -- the MSI package doesn't give much control over environment vars.In the meantime, you can do a custom install and deselect the "Environment" package. This will leave your env vars untouched. You can set them yourself (see fuzzy_toolkit_setup.bat in the installation dir) or run houdini from the "Command Tools" shortcut installed by the package. As far as I know, there's no way uninstalling fuzzy toolkit will uninstall houdini. I've uninstalled and reinstalled ft countless times while testing the MSI and houdini has never been affected. My apologies if your computer has asplode. Linux version coming soon. And from the not-so-subtle rumours flying around the houdini forum, I'll have to support Mac soon, too. :-) cheers, -Mark The problem with this method is that all versions of Houdini get effected, so I have multiple installs of different versions of houdini and they then all try and read dso's that aren't intended for them and throw errors. Quote Link to comment Share on other sites More sharing options...
altbighead Posted April 4, 2008 Share Posted April 4, 2008 The problem with this method is that all versions of Houdini get effected, so I have multiple installs of different versions of houdini and they then all try and read dso's that aren't intended for them and throw errors. hey i think that's the problem im faceing now.Do you know how to fix it? Quote Link to comment Share on other sites More sharing options...
abvfx Posted April 7, 2008 Share Posted April 7, 2008 (edited) i cant get this to work. I plug a poly sphere with normals into the Fur (Fuzzy) and set the display flag on it. Then it crashes. Segmentation Fault. dont know what im doing wrong but am i doing it the right way. cheers -andy bwt way im using, windows xp, houdini 9.173 Edited April 7, 2008 by phrenzy84 Quote Link to comment Share on other sites More sharing options...
sibarrick Posted April 7, 2008 Share Posted April 7, 2008 hey i think that's the problem im faceing now.Do you know how to fix it? Uninstall the fur thing then you either have to edit the HOUDINI_PATH and HOUDINI_DSO_PATH to remove the references to the fuzzy toolkit, or delete them if you weren't previously using them. Quote Link to comment Share on other sites More sharing options...
abvfx Posted April 7, 2008 Share Posted April 7, 2008 anyone got this thing running on linux. I PM'ed mark, but ive done everything now, sourced every etc. But when i run Houdini, its not in the Sop menu. hope someone can help. Quote Link to comment Share on other sites More sharing options...
abvfx Posted April 10, 2008 Share Posted April 10, 2008 (edited) anyone? edit:// BINGO! hit the nail on the head. I dont have any of the directories that pete is talking about (below). Im not adding a reply because i dont think this thread needs me as the last response on the General Chat forum again. wish i had said i was on 32bit from the begining. Edited April 24, 2008 by phrenzy84 Quote Link to comment Share on other sites More sharing options...
pbowmar Posted April 24, 2008 Share Posted April 24, 2008 Hi Mark, The 32bit Linux seems to only have an include dir and a lib dir, no OTLs, Config, OPlibraries etc... Cheers, Peter B Quote Link to comment Share on other sites More sharing options...
markv Posted May 3, 2008 Author Share Posted May 3, 2008 Ah crap... my development environment is 64-bit, and I didn't notice the 32-bit archive was corrupt. I'm releasing an update shortly. cheers, -Mark Hi Mark,The 32bit Linux seems to only have an include dir and a lib dir, no OTLs, Config, OPlibraries etc... Cheers, Peter B Quote Link to comment Share on other sites More sharing options...
markv Posted May 8, 2008 Author Share Posted May 8, 2008 0.9.17 is now available. Linux 32-bit, 64-bit, and Windows 32-bit should all work. Changes: - Help is now available on every node - Misc bug fixes http://www.orthonormalsoftware.com cheers, -Mark Quote Link to comment Share on other sites More sharing options...
abvfx Posted May 9, 2008 Share Posted May 9, 2008 my predictions were not wrong! This thing is amazing. Thank you for taking the time to include the demo's because they really showed me the power of this thing. I now feel i have almost complete control over what i am creating. I think it's time to start/finish that mouse i was creating, and then for the next project. Thank you so much mark. It was worth the wait. -andy Quote Link to comment Share on other sites More sharing options...
curveU Posted May 24, 2008 Share Posted May 24, 2008 (edited) Hi phrenzy84, How did you fix the installation problem? I run the "fuzzytoolkit.install" file and use the default directory "[/opt/fuzzytoolkit0.9.17] " to install it. Should I choose some specific folder to install it? Thanks, Edited May 24, 2008 by curveU Quote Link to comment Share on other sites More sharing options...
abvfx Posted May 26, 2008 Share Posted May 26, 2008 but you need to source it, source fuzzytoolkit.bash ... Make sure you source houdini before you do though. Unfortunately i cannot get this thing to work with imported geometry. Houdini crashes everytime. I replicate everything from the brush setup, but it wont work. I know i have everything right but i can only use it on boxes and spheres created ni Houdini. But i make sure it has the exact same attributes that the sphere or box has before going into the Groom node and then the Default Shops, the brush and finally Build. Any thoughts anyone? Quote Link to comment Share on other sites More sharing options...
curveU Posted May 26, 2008 Share Posted May 26, 2008 thanks. seems there are still some problems with this tool right now. Quote Link to comment Share on other sites More sharing options...
abvfx Posted May 26, 2008 Share Posted May 26, 2008 have you tried the sample file. Its a great file showing how all the different aspects of the toolset works. Quote Link to comment Share on other sites More sharing options...
michael Posted May 26, 2008 Share Posted May 26, 2008 I'm moving this thread to the HDK section... Quote Link to comment Share on other sites More sharing options...
curveU Posted May 26, 2008 Share Posted May 26, 2008 have you tried the sample file. Its a great file showing how all the different aspects of the toolset works. thanks. I will try it out. Quote Link to comment Share on other sites More sharing options...
markv Posted June 4, 2008 Author Share Posted June 4, 2008 Unfortunately i cannot get this thing to work with imported geometry. Houdini crashes everytime. Hey Phrenzy, could you e-mail me a hip file that crashes? Please send it to mark@orthonormalsoftware.com cheers, -Mark Quote Link to comment Share on other sites More sharing options...
abvfx Posted June 7, 2008 Share Posted June 7, 2008 Hey Phrenzy, could you e-mail me a hip file that crashes? Please send it to mark@orthonormalsoftware.comcheers, -Mark Done Quote Link to comment Share on other sites More sharing options...
kensonuken Posted August 26, 2008 Share Posted August 26, 2008 hey Mark, Can you share the vex code for the shader that you have used to generate this kind of fur? please we have been struggling to get the look... Quote Link to comment Share on other sites More sharing options...
kensonuken Posted August 26, 2008 Share Posted August 26, 2008 Hi Markv I love the work that you did for the Furkit but I would like to see the vex code for the shader I want to use the latest cvex with your vex fur shader. Can you please tell me so that i can put few more improvements on top of that? someone rendered out using ur fur system.. http://forums.odforce.net/index.php?act=at...ost&id=5457 it looks very nice to me so sir pls help me with the vop pls.. Quote Link to comment Share on other sites More sharing options...
