My Fur Stuff
Nasyrov
Ver: 1.03
Date: 12.03.08
A little help:
INPUTS:
skingeo - path to the skin geometry. Skin geometry must have normal for the proper setup. Example: /obj/skin
MAIN:
calculate skin normals - calculate and rewrite skin normals
calculate skin uv - calculate and rewrite skin uvs
points - the number of points in each hair
guide density - the number of guides
density - the final number of hairs
seed - seed number
display ratio - display/render ratio of hairs
length scale - length coefficient
length map - length coefficient map
randomize length - simply length randomization
cut map - cut coefficient map
displacement map - a map which displace hairs by root point normals
displace direction - Up (black = no displace)
Up and Down (gray = no displace)
Down (white = no displace)
displacement scale - displacement coefficient
root thickness - root thickness of hair
tip thickness - tip thickness of hair
blend point - blend point of root and tip thickness
blend width - blend region
SHADER:
calculate occlusion - generates 5 pclouds with occlusion values for occlusion baking(generation takes place as separate render)
use texture - enables root and tip textures(using of hair st)
use skin texture - enables root and tip textures(using of skin uv)
root tint - root color multiplyer of hairs
root map - root color map(is enable only if "use texture" is on)
root skin map - root color map(is enable only if "use skin texture" is on)
tip tint - tip color multiplyer of hairs
tip map - tip color map(is enable only if "use texture" is on)
tip skin map - tip color map(is enable only if "use skin texture" is on)
Kd - diffuse coefficient
speccolor - specular color of hairs
Ks - specular coefficient
roughness - specular roughness
addocclusion - read 5 pclouds which were created beforehand, then multiply surface shadere diffuse values by values from pclouds
Kocc - occlusion coefficient
Surface opacity - hair opacity
Edited by Nasyrov
I'm trying this out - looks promising, thanks for sharing!
One issue, the "file mode" dropdown in dynamics->interaction is empty.
Some sort of random variation for the tip/root colors would be a nice feature.
Having two colors for each and then getting a random color between those per hair would be cool.
eetu.
eetu.
mmm...and call the mix salt and pepper, eetu? hah,hah...gotcha! ;)
Tested a bit more;
What does (length) map blend do?
File mode would be nice, i'd like to precalc my sdf's :)
I can't really get any effect out from the skin root map, might be my fault though.
Clumps work weirdly (the problem might be in my end again..)
Skin geo doesn't take obj level animation into account.
eetu.
That's Ok man I'll figure it out. There's some tutorials in the new documentation they teach you how to paint , comb and cut the fur. They're a bit too hard to follow at times and their instructions are kinda weird (i.e. they don't work at times). The OTL looks good man can't really get a photorealistic result keep at it.
Cheers
-S
