cs00bren Posted February 26, 2003 Share Posted February 26, 2003 stupid question but how do you change the pivet point.so that i can rotate it around a different point. i know i have to change the world location or something but can't fined it. cheers for the reply about the network render all i have to do is leave it on the server cheers bren. Quote Link to comment Share on other sites More sharing options...
edward Posted February 26, 2003 Share Posted February 26, 2003 Change the numbers in the Pivot parameter? Are you trying to do this for modeling or animating? Quote Link to comment Share on other sites More sharing options...
cs00bren Posted February 26, 2003 Author Share Posted February 26, 2003 for animation so that a object rotats around one if it's corners. cheers bren. Quote Link to comment Share on other sites More sharing options...
cs00bren Posted February 26, 2003 Author Share Posted February 26, 2003 when you mean pivet paremeter do you mean in the obj level if so i don't understand as i'm trying to do it in the sops level to rotate a object around onother piece of geometry. i hope i made sence, bren Quote Link to comment Share on other sites More sharing options...
edward Posted February 26, 2003 Share Posted February 26, 2003 I'm a bit lost. You want to animate a piece of geometry rotating about another piece? When I say "animate", I mean more or less move it through time when the playbar is playing. Since you say you're at the SOP level, then I would suggest putting down a Transform SOP and changing it's Pivot parameter. If you simply want to rotate a piece of geometry for modelling purposes, then it's sufficient to simply hit the apostophe (') key to detach the handle. Move the handle to your pivot location and then hit the ' key again. Now you can rotate your geometry. Usually, when I detach a handle, I also turn on snapping because I want to place the pivot at a specific point. Quote Link to comment Share on other sites More sharing options...
cs00bren Posted February 27, 2003 Author Share Posted February 27, 2003 i finally figurd it out i don't know what i was thinking it was stareing me right in the face. cheers anyway bren. Quote Link to comment Share on other sites More sharing options...
