maharzan Posted March 13, 2008 Share Posted March 13, 2008 I have a X1950 ATI Sapphire GFX card 512MB and it seems pretty slow with Houdini. Does anyone know about how we can speed things up or have optimal settings so it works smoothly with Houdini? The latest drivers didn't work in Houdini. There were error in the network pane as it tries to write a smaller window in that pane. Thanks for your help.. Quote Link to comment Share on other sites More sharing options...
mark Posted March 17, 2008 Share Posted March 17, 2008 (edited) I have the same card. in XP (32 bit, not sure about 64) houdini does the thing you mentioned. if you search the sidefx.com forums for 'ATI' you will see a thread and it says which version to revert to.. the version from about mid-2007 works well for houdini (not so great for newer games ) for me it worked perfectly in vista with latest ATI drivers.. i thought yay problem solved... but then next time i tried it houdini wouldnt run grrr. i hope to solve that still. reverting to the older ATI drivers or dual booting to linux (not suse 10.3) is all i can suggest. Edited March 17, 2008 by mark Quote Link to comment Share on other sites More sharing options...
maharzan Posted March 18, 2008 Author Share Posted March 18, 2008 Yup, I did revert to an older version which fixed the UI problem. I was wondering if there were other methods to speed things up with houdini.. Quote Link to comment Share on other sites More sharing options...
