Thoi Posted 18 hours ago Share Posted 18 hours ago Hi, I’m designing a physical modular column made from flat panels. Each panel needs a simple interlocking edge (tabs/slots or tongue-and-groove), repeated over several stacked segments for 3D printing. Is there a good procedural way in Houdini to: generate the panels add parametric interlocking geometry on the edges control number of segments Should I build one locking unit and copy it to edges, or is there a better workflow for parametric joints? Any tips, nodes, or example HIPs would be very helpful! Quote Link to comment Share on other sites More sharing options...
Librarian Posted 12 hours ago Share Posted 12 hours ago (edited) @Thoi Aloha ! Tjena! Do you have Some illustration on panels??? https://blog.iaac.net/pexel-exploring-parametricism-through-the-lens-of-modularity/ Edited 12 hours ago by Librarian Quote Link to comment Share on other sites More sharing options...
