Modular Panel System With Interlocking Edges – Best Houdini Workflow?
Thoi
Hi,
I’m designing a physical modular column made from flat panels. Each panel needs a simple interlocking edge (tabs/slots or tongue-and-groove), repeated over several stacked segments for 3D printing.
Is there a good procedural way in Houdini to:
  • generate the panels
  • add parametric interlocking geometry on the edges
  • control number of segments
Should I build one locking unit and copy it to edges, or is there a better workflow for parametric joints?
Any tips, nodes, or example HIPs would be very helpful!
