Coz_y_not Posted yesterday at 03:51 PM Share Posted yesterday at 03:51 PM The body in grey is moving. The main rotor in orange and tail rotor in red are rotating based on $CEX $CEY $CEZ, and are supposed to follow the motion of the body, but it's jittery and keeps moving from it's place. Am i doing it wrong? is it doable with transform or do I have to use APEX for this kind of animations? main Rotor animation transform tail transform node Quote Link to comment Share on other sites More sharing options...
tamagochy Posted yesterday at 05:55 PM Share Posted yesterday at 05:55 PM you need to check pivot point position. looks like it not in the rotation center Quote Link to comment Share on other sites More sharing options...
Coz_y_not Posted yesterday at 07:38 PM Author Share Posted yesterday at 07:38 PM 1 hour ago, tamagochy said: you need to check pivot point position. looks like it not in the rotation center Although I have changed the pivot it still has that jitter Quote Link to comment Share on other sites More sharing options...
tamagochy Posted yesterday at 07:53 PM Share Posted yesterday at 07:53 PM (edited) You need to place it manualy, you object not symmetric Edited yesterday at 07:54 PM by tamagochy Quote Link to comment Share on other sites More sharing options...
Coz_y_not Posted yesterday at 08:13 PM Author Share Posted yesterday at 08:13 PM 14 minutes ago, tamagochy said: You need to place it manualy, you object not symmetric it's a long animation, I can't place it manually for every frame, and the body is moving. it is symmetric 3.3313 x 3.33132 Quote Link to comment Share on other sites More sharing options...
tamagochy Posted 5 hours ago Share Posted 5 hours ago No need to do it in each frame, before tarnsform main body add points to rotation center of each rotor. Than apply transform to body, in rotor rotation transform refer pivot point to points you add before. Quote Link to comment Share on other sites More sharing options...
