unstable helicopter rotors animation (rotation in transform node)
The body in grey is moving. The main rotor in orange and tail rotor in red are rotating based on $CEX $CEY $CEZ, and are supposed to follow the motion of the body, but it's jittery and keeps moving from it's place.
Am i doing it wrong? is it doable with transform or do I have to use APEX for this kind of animations?
main Rotor animation transform
tail transform node
No need to do it in each frame, before tarnsform main body add points to rotation center of each rotor. Than apply transform to body, in rotor rotation transform refer pivot point to points you add before.
  • 2 months later...
It's a tricky geometry, the rotors are not separate, So that wouldn't work I think. I attach the helicopter geometry.
helicopter_.rop_geometry.bgeo.sc
