zasid Posted April 10, 2008 Share Posted April 10, 2008 (edited) Hello wants to know,why is it so hard to divide ring selection of edges in houdini with edge divide?Is it something I m doing wrong ??please check the hip file. When I asked it to use close path it leaves 1 or more edges unconnected . edgedivide_problem.hip Edited April 10, 2008 by zasid Quote Link to comment Share on other sites More sharing options...
old school Posted April 10, 2008 Share Posted April 10, 2008 checked. submitted. 30467 Quote Link to comment Share on other sites More sharing options...
primzahl Posted June 26, 2008 Share Posted June 26, 2008 hello, facing the same problem - is there now a solution ? thanks -pz- Quote Link to comment Share on other sites More sharing options...
zasid Posted June 26, 2008 Author Share Posted June 26, 2008 Hello Guys, I have figured out how to solve it.Actually u will have to very careful with ur edge selection although other softwares like Lightwave, MAX, MODO and others which are smart enough to judge your ring selection. Anyways this is you should do. Select your edges in numbered ordered like clock wise or anticlock wise one by one Apply edge divide it will never go wrong If you will select your edge ring in one go you will not be able to get the rite results. As for the improvements I would suggest SESI to provide some smart RING selection tools. like modo or max. thanks . Quote Link to comment Share on other sites More sharing options...
old school Posted June 27, 2008 Share Posted June 27, 2008 Agreed that the loop selection should be made smarter when it hits points with three or five (or more) edges. -jeff Quote Link to comment Share on other sites More sharing options...
primzahl Posted June 30, 2008 Share Posted June 30, 2008 Hello Guys,Select your edges in numbered ordered like clock wise or anticlock wise one by one Apply edge divide it will never go wrong thanks . Thank you for this hint. Works perfectly - maybe not really fast, but it works. -pz- Quote Link to comment Share on other sites More sharing options...
Morgan Nilsson Posted February 28, 2014 Share Posted February 28, 2014 Sorry for bumping this thread, but wondering if there are any solutions to this problem? It is really cumbersome having to select the edges in order. Quote Link to comment Share on other sites More sharing options...
