render points as lines ... without particles
frading
Hello,
I am trying to render points as lines, without using particles, since I manipulate my points with expressions.
If I was using particles I could use a render POP, but I need another way.
And since the render POP seems to set a parameters inside the particle primitive, which is invisible in the detail view or attribute list, that just appears in the bgeo or ifd, I dont see another way to force the points to render as lines.
in the IFD, at the end of the geometry definition, a render POP would add lines like:
beginextra
prender blablabla
endextra
Is it something I could add with a mantra procedural shader? if yes, I dont see how.
I could also add those lines in the IFD with python but I am hopping for something simpler :)
let me know if you can enlight me :)
Guillaume
Well, I am allready rendering my particles through instances (because I am dealing with dozens of millions) and I assume I cant have instances of instances, can I?
But anyway, I solved my problem by doing 2D motion blur by outputing velocity vectors, which will achieve a very similar look. so it will be allright
cheers
Guillaume
