platypus Posted March 5, 2003 Share Posted March 5, 2003 I have a Grid SOP that I appended a Point SOP to and then plugged in expressions for the x and z positions, in order to get a log spiral (as in the "expression cookbook" part of the documentation)... i then created a circle and have copied it to the spiral points. problem is that I can't seem to get the circles to align properly, ie all aligned towards the center of the spiral. cant even seem to get them to simply align to each point properly in order to create a "tube" of cicles either. they keep on ending up flattened out. (see image) i have tried appending a second Point SOP to the spiral, using "add normal", etc... but no luck. any suggestions? Quote Link to comment Share on other sites More sharing options...
platypus Posted March 5, 2003 Author Share Posted March 5, 2003 oops... sorry about the double post. not quite sure what happened there. Quote Link to comment Share on other sites More sharing options...
Marc Posted March 5, 2003 Share Posted March 5, 2003 Don't worry, I fixed it As for the normals. You may want to take a look at the flownormals vex SOP written by charles. Its in the codex somewhere (geometry probably). That should help you control your normals better. Cheers Marc oh, uh.... also, you could try using sweep instead of copy. That will give you better results without messing with the normals. Quote Link to comment Share on other sites More sharing options...
platypus Posted March 6, 2003 Author Share Posted March 6, 2003 ahhh! yes indeed, the Sweep SOP did the trick. if it were a snake, it would've bit me. thanks Marc. Quote Link to comment Share on other sites More sharing options...
Marc Posted March 6, 2003 Share Posted March 6, 2003 good thing it wasn't a snake then.... .... ouch. Marc Quote Link to comment Share on other sites More sharing options...
