is it possible to template an geometry at object level?
spev
When inside a geo node it is possible to template geometry ..but when you go up a level out of sops the geo dissapears...is it possible to get the same behaviour as the camera so that when you go to the top level the geo displays as if it were templated (in wireframe) as per camera?
any help, as always, would be gratefully appreciated.
Ta
Spev
just simply ghost or display all contents. its the button with the circle, box and a tube on it, right next to your how you want to display the geo button.
upper right corner of your viewport, should jump in your face.
Is it that, what you searching for?
Cheers
-J
