khuong Posted May 12, 2008 Share Posted May 12, 2008 Hi all, i'm new to Houdini. I set up a liquid fluid that falling on some spheres and box but i don't know why the fluid just only collides on the spheres but the box, i've tried many way to figure out in vain. All the spheres and box in Geometry node and set to Polygon. The fluid always goes through the box... Anyone, please help. Thank you very much Khuong Quote Link to comment Share on other sites More sharing options...
stevenong Posted May 12, 2008 Share Posted May 12, 2008 Merge the box & sphere together before merging them with the liquid. If this doesn't work, please post your hip file. Cheers! steven Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted May 12, 2008 Share Posted May 12, 2008 (edited) The default merge is Left Affects Right, so make sure all your spheres and boxes are placed to the left of the fluid object in the merge dop. Edited May 12, 2008 by GallenWolf Quote Link to comment Share on other sites More sharing options...
khuong Posted May 12, 2008 Author Share Posted May 12, 2008 Thanks Steven, GallenWolf for fast reply I attached the .hip file for your reference. Quote Link to comment Share on other sites More sharing options...
khuong Posted May 12, 2008 Author Share Posted May 12, 2008 Thanks Steven, GallenWolf for fast reply I attached the .hip file for your reference. Cheers. Thank you fluid_test.hipnc Quote Link to comment Share on other sites More sharing options...
vmuriel Posted May 12, 2008 Share Posted May 12, 2008 Two problems in your scene: 1.- Low resolution fluid. It has an easy fix, increment size param in your Fluid Object. 2.- Your collision guide geometry do not fit with your real geometry. Fixs: Increment the divisions of your collision guide. Increment the axis divisions in your box geometry. Change primitive type to Polygon Mesh. If is posible, increment the y size of your box, the collision guide geometry detections will work better. Quote Link to comment Share on other sites More sharing options...
khuong Posted May 12, 2008 Author Share Posted May 12, 2008 Two problems in your scene:1.- Low resolution fluid. It has an easy fix, increment size param in your Fluid Object. 2.- Your collision guide geometry do not fit with your real geometry. Fixs: Increment the divisions of your collision guide. Increment the axis divisions in your box geometry. Change primitive type to Polygon Mesh. If is posible, increment the y size of your box, the collision guide geometry detections will work better. Thanks vmuriel, i'll give it a try Quote Link to comment Share on other sites More sharing options...
khuong Posted May 13, 2008 Author Share Posted May 13, 2008 Thank you for your advice vrmuriel, it works one more thing i want to ask you that when i scaled down the box to make it thinner like a piece of wood, the fluid still goes through it... although i increased the axis divisions.... how can i do to fix it? thanks Quote Link to comment Share on other sites More sharing options...
