zasid Posted May 16, 2008 Share Posted May 16, 2008 Hello guys ! I have a problem. I have fractured object that is being effected by 2 gravity forces 1 in X so and one in Y so that certain chunks can fall at certain time when I want them. but when they fall they keep rotating I unlock the DOP and change the rotation stiffness to set always but it doesn't seems to work.Have tried alot of things but it didn't work. Can some one help me with this .Its kinda important. Many Thanks .m posting the hip file with the obj also. It will also be great if you can tell suggest me a better way for this effect which is more effiecient like certain object go in X direction and cetain fall in certain time in Y direction. Many thanks Rotation_Problem.zip Quote Link to comment Share on other sites More sharing options...
SpencerL Posted May 16, 2008 Share Posted May 16, 2008 Check out the Auto Freeze DOP Quote Link to comment Share on other sites More sharing options...
zasid Posted May 16, 2008 Author Share Posted May 16, 2008 Check out the Auto Freeze DOP I tried with RBD Autofreeze but they keep on rotating still. Quote Link to comment Share on other sites More sharing options...
