Vex Export parameter Code
rob
Has anyone got any advice for adding export parms to shaders using vex code ? The help has not really helped ! .
The code from an example Vop network gives me 3 main areas
// labels
#pragma label paintExport paintExport
#pragma hint paintExport color
#pragma hint paintExport invisible
// declared as part of the shader
export vector paintExport = { 0, 0, 0 };
export vector diffuseExport = { 0, 0, 0 };
export vector specularExport = { 0, 0, 0 };
export vector opacityExport = { 0, 0, 0 };
// bound value
bound_paintExport = isbound("paintExport");
paintExport = product;
I presume the bound value is the most important. I just dont know where to deploy this and in what context . Is there any chance I could have a simple example to look at.
Rob
Hi Steven,
I know its used for exporting a parameter , but I dont see how I can add "export vector paintExport = { 0, 0, 0 };" then successfully use
when I have no value called product in my shader. I presume I could define any value to bound for export but so far with not much success in my code.
rob
Hey Rob,
You'll have to paste the entire shader code here so we can determine where product is defined. isbound() is used to check whether the geometry has the attribute. If the geometry has the attribute, use the attribute "bound"-ed and override the shader's parameter.
From the VEX help docs:
isbound vex function
Parameters in VEX can be overridden by geometry attributes (if the attributes exist on the surface being rendered).
Hope the above helps!
Cheers!
steven
