goldleaf Posted May 30, 2008 Share Posted May 30, 2008 I'm trying to import some obj models into Houdini that consists of different pieces of geometry, but Houdini imports them as one piece, and I can't find a node that separates or breaks them apart. How can this be done in Houdini? Quote Link to comment Share on other sites More sharing options...
kubabuk Posted May 30, 2008 Share Posted May 30, 2008 If you middle click on the file SOP you should see some groups you imported geometry comes with. Use delete SOP to separate them. If your geometry is a one big chunk, possible solution would be to apply connectivity sop and partition SOP after it with the $class expression in the Rule field. k. Quote Link to comment Share on other sites More sharing options...
goldleaf Posted May 30, 2008 Author Share Posted May 30, 2008 If you middle click on the file SOP you should see some groups you imported geometry comes with. Use delete SOP to separate them. If your geometry is a one big chunk, possible solution would be to apply connectivity sop and partition SOP after it with the $class expression in the Rule field.k. I tried that, but I cant get it to work. Could you provide a screenshot to illustrate the concept? Quote Link to comment Share on other sites More sharing options...
zasid Posted May 30, 2008 Share Posted May 30, 2008 Hi goldleaf , It will be alot faster if u post a hip file with some test obj in a zip file, so that we all can have a look and send u a possible solution. Thanks zasid. Quote Link to comment Share on other sites More sharing options...
goldleaf Posted May 31, 2008 Author Share Posted May 31, 2008 Hi goldleaf ,It will be alot faster if u post a hip file with some test obj in a zip file, so that we all can have a look and send u a possible solution. Thanks zasid. Ah, I think it's working now. It looks like it was a problem with the build I was using and my computer. Thanks! Quote Link to comment Share on other sites More sharing options...
JDenker Posted June 1, 2008 Share Posted June 1, 2008 (edited) with wihich program are you exporting the obj from? im using crosswalk in xsi and the export function in maya quite a lot to bring fbx datas over to houdini. give it a try. never had problems with geo that way. cheers -J Edited June 1, 2008 by JDenker Quote Link to comment Share on other sites More sharing options...
goldleaf Posted June 3, 2008 Author Share Posted June 3, 2008 with wihich program are you exporting the obj from? im using crosswalk in xsi and the export function in maya quite a lot to bring fbx datas over to houdini.give it a try. never had problems with geo that way. cheers -J I'm exporting from Silo. I'll have to figure out how to try with fbx. Thanks for the heads up. Quote Link to comment Share on other sites More sharing options...
