nestumkiller Posted June 6, 2008 Share Posted June 6, 2008 Hi! I was wondering if there's a way to create a dynamic choiceList or something similar. I need to create a node navigator, where the list contains the current node's children, and if I select one and do some button pressing it just goes inside and repopulates the list again. I couldn't find a way of changing the static nature of ChoiceLists, and it occured to me that a good choice would be something like a string field where the entries are selected by me. Does this make sense? Thanks! Quote Link to comment Share on other sites More sharing options...
malexander Posted June 6, 2008 Share Posted June 6, 2008 There is a constructor for PRM_ChoiceList which takes a function pointer (PRM_ChoiceList.h). That version allows you to fill in items, up to 'thelistsize' in number. Don't forget to terminate the list with a NULL token on the last PRM_Name. typedef void (* PRM_ChoiceGenFunc)(void *thedata, PRM_Name *thechoicenames, int thelistsize, const PRM_SpareData *thespareptr, PRM_Parm *theparm); Quote Link to comment Share on other sites More sharing options...
nestumkiller Posted June 9, 2008 Author Share Posted June 9, 2008 Thanks a lot! I actually found some other topic with some more information on this: Group Menu. Anyway, it's working fine now Cheers Quote Link to comment Share on other sites More sharing options...
