eetu Posted October 16, 2015 Share Posted October 16, 2015 did the 32bit version also have this issue, only did some small tests, but seemed fine. but could be it also had it. other coders might, maybe, be able to solve the geometry limit problem, if you found the source files that would be awesome (!) This should be exactly the same as the 32-bit version, just a 64-bit compile with the newest LW 2015 SDK. Find the source attached. The dirty secret is that this is just a modification of the SDK videoscape object loader - ascii 3d formats tend to be rather similar So, originally copyright Newtek/Ernie Wright 2000, but I trust they won't mind. ee_hougeoimport_src.zip Quote Link to comment Share on other sites More sharing options...
erikals Posted October 16, 2015 Share Posted October 16, 2015 (edited) Awesome! i can now try to dig more into this, the project you have here is super-cool... by the way, sounds like LightWave 2016 will be able to (finally) load heavy scenes, handy when loading huge files. Edited October 16, 2015 by erikals Quote Link to comment Share on other sites More sharing options...
erikals Posted September 29, 2017 Share Posted September 29, 2017 strange, i downloaded a trial of 2015.3, however i get an error when trying to add the plugin... couldn't get it to install in 11.6 either unfortunately error msg > cannot load external plug-in file 0 plug-ins found in 1 files not quite sure what the error could be... Quote Link to comment Share on other sites More sharing options...
erikals Posted October 1, 2017 Share Posted October 1, 2017 Seems to be fixed! http://forums.newtek.com/showthread.php?154749-Houdini-geo-plugin-can-u-test&p=1519104#post1519104 do note, it reads .hclassic though, and not .geo files, so exporting from Apprentice will not work. still, great stuff ! Quote Link to comment Share on other sites More sharing options...
erikals Posted October 1, 2017 Share Posted October 1, 2017 (edited) tagging along, it seems i found a missing function ? from what i can see, the plugin looks to export points only, no mesh. [video] https://www.youtube.com/watch?v=9fMfbSfhJfY (note: the 32 bit plugin had the same issue, however i thought i was doing something wrong, so unfortunately didn't notice it at the time) Edited October 1, 2017 by erikals Quote Link to comment Share on other sites More sharing options...
erikals Posted October 24, 2018 Share Posted October 24, 2018 (edited) Oliver & Wolf has made a motion blur plugin https://forums.newtek.com/showthread.php?155473-OD-2018-Tool-Set-Released&p=1557095&viewfull=1#post1557095 Edited October 24, 2018 by erikals Quote Link to comment Share on other sites More sharing options...
