rob Posted June 16, 2008 Share Posted June 16, 2008 Unable to get VEX code from: opdef:/Shop/rs_amb_hemisphere mantra: VEX error: Unable to load opdef:/Shop/rs_amb_hemisphere Path not found This happens every so often or not to newly created otl files. The only way I find to correct it is to delete the file and start all over again. Is this happening for anybody else ? 9.5.126 Rob Quote Link to comment Share on other sites More sharing options...
hoknamahn Posted June 16, 2008 Share Posted June 16, 2008 (edited) This happens every so often or not to newly created otl files. The only way I find to correct it is to delete the file and start all over again. Is this happening for anybody else ? 9.5.126 Rob What if to turn on Force VEX shader embedding? Edited June 16, 2008 by hoknamahn Quote Link to comment Share on other sites More sharing options...
rob Posted June 17, 2008 Author Share Posted June 17, 2008 (edited) Where do I turn that on ? .In any case I think the errors run far deeper with otls and windows. Right now I can create a new light shader otl which contains code from a previous shader that I have been working on. It should be blank in the code area. Rob Edited June 17, 2008 by rob Quote Link to comment Share on other sites More sharing options...
hoknamahn Posted June 17, 2008 Share Posted June 17, 2008 Where do I turn that on ? .In any case I think the errors run far deeper with otls and windows. Right now I can create a new light shader otl which contains code from a previous shader that I have been working on. It should be blank in the code area.Rob It's here Mantra ROP -> Properties -> Render -> Force VEX Shader Embedding. I saw one problem but not sure does it have the same roots as your problem - when Houdini loosing VEX code from OTL. Quote Link to comment Share on other sites More sharing options...
