cloudfx Posted June 18, 2008 Share Posted June 18, 2008 (edited) Hi all, I am using the delete sop to delete my obj using bounding volume. I animated size of the bounding volume and it moving from center to edge of the object. When the primitive starts to deleted by the bounding volume, it gets a crazy velocity. I guess the velocity is inherited by the bounding volume, if I see the velocity vector. OR, is it just because there is no previous or next frame of obj is not exist, I could make one but its deleted by animated bounding volume, so it wont work, isnt it?(tell me if I can!) I tried the transform sop and animated scale with a little super-tiny value (ex: 1 + $FF / 99999999) to make at least a little bit of velocity there to prevent getting velocity from something else.. but its not working too.. But, is there other way to solve this problem?? Thanks, Edited June 19, 2008 by Jae Yoo Quote Link to comment Share on other sites More sharing options...
edward Posted June 19, 2008 Share Posted June 19, 2008 Put your Delete SOP after the Trail SOP. Quote Link to comment Share on other sites More sharing options...
cloudfx Posted June 19, 2008 Author Share Posted June 19, 2008 Put your Delete SOP after the Trail SOP. Hi, However, I am using extrude and group sops which is kind of complicated so I cant put delete sop before trail sop.. Quote Link to comment Share on other sites More sharing options...
edward Posted June 19, 2008 Share Posted June 19, 2008 No, the Delete SOP after the Trail SOP. Quote Link to comment Share on other sites More sharing options...
cloudfx Posted June 19, 2008 Author Share Posted June 19, 2008 No, the Delete SOP after the Trail SOP. So, There is no other way work around to get it..? is that only way..?? Quote Link to comment Share on other sites More sharing options...
edward Posted June 19, 2008 Share Posted June 19, 2008 Well, without understanding why your Trail SOP depends on the Delete SOP ... Quote Link to comment Share on other sites More sharing options...
old school Posted June 19, 2008 Share Posted June 19, 2008 Are you using the Delete SOP because you simply have too much data and you are trying to get speed up (or for whatever reason...). Either way, the Trail SOP approach to calculating velocity really doesn't work well when you delete arbitrary points in the input. e.g.: Point 300 is deleted on the current frame. Point 301 now becomes Point 300. The velocity is now incorrect for point 300! If you can use an alternate attribute such as id, then you can work around this by using a Sort SOP > sort points by attribute then Trail SOP. There are other ways to feed in a stable point set in to the Trail SOP as well (CHOPs, mdd caches, etc...). Quote Link to comment Share on other sites More sharing options...
