cloudfx Posted June 20, 2008 Share Posted June 20, 2008 Hi all, For example, If I cached 50 frames of smoke in fluid, where does cached smoke data go? Quote Link to comment Share on other sites More sharing options...
edward Posted June 21, 2008 Share Posted June 21, 2008 If you didn't specify a file, then I assume in memory? Quote Link to comment Share on other sites More sharing options...
cloudfx Posted June 22, 2008 Author Share Posted June 22, 2008 If you didn't specify a file, then I assume in memory? hi!- where do I specify the output cache files?? Quote Link to comment Share on other sites More sharing options...
SpencerL Posted June 22, 2008 Share Posted June 22, 2008 hi!-where do I specify the output cache files?? File DOP Quote Link to comment Share on other sites More sharing options...
