JoshJ Posted June 21, 2008 Share Posted June 21, 2008 Hello, Let's say I have several objects in a digital asset. I've promoted parameters of each object into the top level interface of the HDA. How can I make the folders switch to the correct object's parameters whenever that object is selected? Quote Link to comment Share on other sites More sharing options...
edward Posted June 22, 2008 Share Posted June 22, 2008 Make sure the preference is turned on under Edit > Handles(?) .... Second, make sure the objects inside have their selectable (green) flag turned on. Forth, make sure the parameters to span different folders. eg. don't promote tx and ty to different folders. Quote Link to comment Share on other sites More sharing options...
JoshJ Posted June 23, 2008 Author Share Posted June 23, 2008 When I was selecting objects, the folders were in fact switching, however they were switching to the wrong objects! At that time, I had the transform and subnet controls from the subnet still at the top of the asset. I moved them to the bottom in the type properties parameter interface, and the folders switched correctly at that time. This brings up an important question, in complicated assets (such as the toon character), how can one precisely control the folder that opens upon selection of different parts? Is there a good way to control the behavior? I saw some things about "std_switcher" before, but never have seen clear instruction on how to do this. edward said: Make sure the preference is turned on under Edit > Handles(?) .... Second, make sure the objects inside have their selectable (green) flag turned on. Forth, make sure the parameters to span different folders. eg. don't promote tx and ty to different folders. Quote Link to comment Share on other sites More sharing options...
edward Posted June 23, 2008 Share Posted June 23, 2008 I should have also mentioned that say you also can't promote the translate and rotate parameters from the same object into different folders. When you select the object, the handle is binding to the translate/rotate/scale parameters and will follow the channel references up. So if you have them split into different folders, then it can only switch to one of them. Quote Link to comment Share on other sites More sharing options...
JoshJ Posted June 23, 2008 Author Share Posted June 23, 2008 I promoted each whole object's parameters to the top level of the digital asset, so each object had its own folder with the respective TRS Pivot etc. controls within each folder. What I'd like is a way to specifically control which folder is switched to, when Houdini's default decision malfunctioned. edward said: I should have also mentioned that say you also can't promote the translate and rotate parameters from the same object into different folders. When you select the object, the handle is binding to the translate/rotate/scale parameters and will follow the channel references up. So if you have them split into different folders, then it can only switch to one of them. Quote Link to comment Share on other sites More sharing options...
michael Posted June 23, 2008 Share Posted June 23, 2008 please add to this thread here: http://www.sidefx.com/index.php?option=com...pic&t=11489 it'll take me a while to provide an example file but if you have an asset that is broken please send it to mark (mtucker) Quote Link to comment Share on other sites More sharing options...
