run python script from button in node
Fomal
I made a python script that runs from the shelf. I'd like to have the script run when I press an update button created in a node. Looked at the callback function but can't figure out how to get it to work.
Hope someone can help
cheers Coen
In the "scripts" tab of your hda add a PythonModule and put your function there, e.g. def runMe()
In your button callback, enter hou.pwd().hdaModule().runMe()
Better if you take a look at the mdd writer hda at http://undo.fi/houdini/mdd/ - it has a button set up that runs a script.
There might be better ways to do it, but at least that works for me :)
eetu.
thanks eetu,
starting to make sense now. But is that only suitable for digital asset? Just trying it on a null now and the method doesn't seem to work
Edited by Fomal
  • 8 months later...
Nevermind... Got it to work, forgot some brackets :blink:
Thanks for the example eetu
Hey guys,, I'm trying this out now.. on a null..? how did you get it working Coen/Fomal..? or do I have to make it into a hda..?
I'm struggling to shovle the script into a function also..?
any help would be great..?
cheers
ben.
