mihai architect Posted July 4, 2008 Share Posted July 4, 2008 Hi guys ! I'm trying to animate something very simple example, like translating and rotating cube and I wonder if there is any way to keyframe a particular channel in the scene viewport, somehow clicking on the transform handles (for example I want to key only translate on y, or rotate on x,etc), because if I press K all the transform channels are keyed and I get useless keyed information in the channel editor since the other components are not transformed. I read in the help that there is a "key handle" hotkey whitch is CTRL+K, and to me it sounds like what i'm looking for, but I don't know how to use it. It's for sure something that I'm doing wrong. I have to mention that I tryied the Shift+t/r/e and indeed it's a little better but still it is keying hole translate or rotate channel (on all x y z components). And the ALT+click in the parameters transform panel it's the only method I know of doing this but it's slow for an animation workflow. I want to know how the CTRL+K works and if there is a way to key in the viewport by clicking on the handles or somehow. Thank you very much ! Quote Link to comment Share on other sites More sharing options...
mike Posted July 7, 2008 Share Posted July 7, 2008 Preferences -> Animation -> "Set Keys on Pending Channels" and "Add Keyframes on Parameter Change" Quote Link to comment Share on other sites More sharing options...
