getting into rigging - help highly appreciated
I created a fresh Limb rig
could be used for arm and leg
from what i can tell right now it should work properly
again - every feedback highly appreciated
it can also do knee / elbow stretch for things like having the character kneeing or leaning on its elbow or something
this time i used just expressions
and minimal chops
i don't like expressions because they just look like a mess and are very hard to read
compared to chops or proper coding
Stretchy_Limb2.hipnc
Edited by KrisStaber
These are pretty awesome example files, I learned a bit from them so far, thanks for posting them, and I look forward to seeing more!
and minimal chops
created a finger rig
this should be multiplyable and placeable everywhere (essentially thats a whole hand)
also there is a setup controller (the edgy one is the root and the nulls are the other ones) that allow for resizing the finger rig
please give it a try and let me know what you think or if you see errors or whatever that helps me to improve
finger04.hip
do not know what would this be good for
sorry for being harsh
Edited by kumpa
was able to check out calcas stuff
got a better spine now (especially for puttig it into the limbs with parenting and all that stuff)
check it out
edit
added the basic version with out the ability to set a predifined length and switch stretch on and off
betterspine.mov
betterspine02.hipnc
betterspine_basic_03.hipnc
thanks michael
i need to hand that thing in for my final masters project in 20 days so not far off :-)
:shocking:
do you see antyhing in my files that could be done better or eats up too much processing power ?
what do you have to hand in?
a full rig?
a rigged character?
I'll try to have a closer look at your files and see if I can spot anything...
I'd suggest assembling all the bits into a full biped...before you go too far.
a full rig?
a rigged character?
essentially i am trying to create a proportional rig
something that can be applied to any sort of proportion
essentially it is supposed to have the same functionality as the autorig
just that the setup thing is built in
will also rig two or three characters to show the ability of the setup
at least thats the plan
if i can do it is a different question
I'd do a bit of practicing...
a 3 bone chain and a poly tube
just to get the feel of it...and to see what SOPs Houdini puts down and how they work
the problem is though that i have a broken hirarchy
so i shomehow have to get all the different bones hirarchies to capture one mesh
also i have a few bones in there that should not capture the mesh because they are just helper objects for the rig behaviour
i can select all the bones that should capture
but the capture geo tool wants me to give it ONE hirarchy
