how do you create an fk ik switch in houdini ?
I've only every used one rig in Houdini...not an IK rig and an FK rig etc....
the IK/FK is always done with a blend...
and you can do a switch with some pretty simple scripting - at a given frame jam the bone rotations from the IK into the rotation parameters and jam the bone rotations into the IK solution...
Just as an example to see how sidefx implemented the fk/ik blending:
create a new toon character, right-click on the node: -> allow editing of contents (this will allow you to browse and look inside of it)
Go into the network, right clik on the "right arm" node: -> allow editing of contents
Go into the arm network and take a look at the purple "blend" nodes.
When you refer to Maya's switch, you set it up with rotation constraints and it really is more a blend than a hard switch. The weight of the maya constraint is the same as the weights inside the houdini "blend" node. There is no built-in switch like the one in Maya (like you said, nobody really uses it anyway), you have to set it up yourself with blend nodes. And yes, the ik-solver needs to be applied through chops.
I think that as you go and you decide to implement other things (springy bones) you'll use chops a lot more. Just like in Maya you can blend as many bones with each other as you want.
