making a pipes system
HI guys
I'm working on a pipes system based of a curve, the problem I have is that when a pipe changes plane, the corner joint
won't follow, here's a pic.
I oriented the normals to follow the curve but one the curve goes up, it needs and extra twist.
thanks guys
you can use the cross product of the current normal and the previous normal as an up vector for the copy operation. - this does imply you don't have two point on the same line next to each other without a change of direction, as that will screw up the result of the cross product.
I added color to the cornerpieces to make it visible in which direction they are pointing.
goodluck
copy_cornerpieces_on_curve.hipFetching info...
